Mechanics
BRAKE PROBLEM
Plymouth Voyager
Plymouth Grand Voyager 1998, 160,500 miles V6.
Brakes failed on Saturday, towed to mechanic. They put in new master cylinder, front rotors and pads. Bled the brakes once, tested it and then had to re-bleed the brakes. After the second bleed, I took it home nice and tight. Sunday, drove it about 30 miles and by the end the brakes were as bad as before. Took it back on Tuesday, they bled the brakes a THIRD time, test drove it for miles and I took it home last night with nice tight brakes.
This morning on the way to work. Progressively squishy brakes. Not dangerous yet, but definitely not tight like last night.
Thank you so much.
Tsyzer
February 7, 2007.
Did they change the back ones
Rasmataz
Feb 8, 2007.
AD
