Mechanics
GUAGES AND LIGHTS
Plymouth Voyager
1998 plymouth voyager, approx 75,000 miles
3 part question
1. My instrument guages on the panel won't work at all. All flat, yet there is still light to the panel. What would the cause be? How do I check for the problem and how can I get power to the guages?
2. The " dimmer" part of the dimmer switch doesn't work and when my headlights are on, the panel lights flicker( pulsate ). Are these 2 related? The cause? The check? The fix?
3. When the guages went flat, my wipers lost the intermittent ability. Only one speed now. Cause? How check? The fix?
Could all 3 things above be related/tied together? If so, how? How can each be tested and fixed? Please let me know options for each, test procedures, and anything else you can suggest. THANK YOU!
Linda Maloney
July 10, 2006.
120,000 3.0 lt = I have the same problem. Did you ever find a fix for this? I sure would appreciate some feedback.
Thanks!
Kim
Ksmolinar
Oct 12, 2007.
AD
