1991 Plymouth Voyager
1991 base model Plymouth Voyager 2.5L/auto with approx. 90,000 mi.
New to the forum. Great site guys!
I didn't really see my problem while skimming Dodge & Plymouth forums.
Vehicle shut down while pulling into a parking space as if someone turned off the key. Battery is good and all fuses test good. Lost power to the radio, wipers, gauges/warning lights, turn signals and the starter doesn't even click. I do have headlights, heater blower, emergency flashers interior lights and rear door release working.
I finally found a sevice manager at a local dealership that would talk to me other than saying tow it in.
he suggested a fuseable link had blown and described where they are located and what they look like.
I found the link inline with the red wire going to the 1st relay (front one-radiator fan relay? Per Chilton's) burnt.
I spliced a jumper wire to the remaining pieces.
The link burnt again as soon as I turned on the key, but I did get it to crank for a second.
Could a bad relay cause the link to burn out or might it be something else that is being controlled by the same relay? Could a shorted out fan motor cause this type of problem?
Thanks for your help in advance!
November 2, 2006.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
