Mechanics
MOTOR WILL NOT TURN OVER
1998 Plymouth Voyager
Electrical problem
1998 Plymouth Voyager 6 cyl Front Wheel Drive Automatic
battery is fully charged, the van will not turn over when the key is in the crank and start position. If you unhook the battery for a day or two, it will start and run all day long, when you shut the van off, it might not turn over the next time you try it. I have no power at the starter triger wire but the starter relay is clicking as is the shutdown relay. Any ideas? I havent checked the TSB " tecnicle service buliton yet. Sorry about the spelling.
Andyharley67
September 16, 2009.
The van will not turn over when the key is in the crank and start position.
Which one is your problem
1. Cranks over and will not start?
2. Will not crank at all/nothing?
Rasmataz
Sep 16, 2009.
