Fuel filter
SCHWEITZ
  • 2000 PLYMOUTH VOYAGER
  • 6 CYL
  • 76,000 MILES
Where is the fuel filter located?
Tuesday, November 11th, 2008 AT 1:29 PM
DAVE H
  • 13,383 POSTS
FUEL FILTER
Removal & Installation
Fuel filter is located on top of fuel tank, near fuel pump module. Fuel lines are permanently attached to fuel filter.
Release fuel pressure from fuel system.
Disconnect fuel lines at fuel pump module and fuel supply line using proper procedure. Remove retaining bolt and fuel filter.
To install, reverse removal procedure. Use proper procedure for installing fuel lines. Turn ignition on and check for fuel leaks.
Tuesday, November 11th, 2008 AT 3:15 PM
AARON STASSI
  • 1998 PLYMOUTH VOYAGER
  • 6 CYL
  • 250,000 MILES
Need to replace fuel filter.
Friday, December 25th, 2020 AT 9:18 AM (Merged)
Hi AARON,
I attached the procedure for the filter. It looks like it is on the tank. Please let me know if you need more information. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Thanks
THORNKNIGHTWOOD
  • 1997 PLYMOUTH VOYAGER
  • 3.3L
  • 6 CYL
  • FWD
  • 130,000 MILES
Is it possible to install an electric external fuel pump? I am getting on in years and want make repairs easier. Having to replace the one in tank is going to be cost prohibitive for me.
I have priced parts to be around $160.00 plus. The labor is probably going to be quite high.
Friday, December 25th, 2020 AT 9:19 AM (Merged)
STEVE W.
  • 12,958 POSTS
Not really as the in tank unit also has the fuel pressure regulator built in. Your external pump would have to draw through the in tank unit and have an external regulator.
The pump assembly is around $120.00 for the OEM Bosch pump. Labor depends on the shop. It is not a hard one to change but if you are in the rust belt it could be worse.
FAULKJAM81
  • 1996 PLYMOUTH VOYAGER
  • 4 CYL
  • FWD
  • 15,000 MILES
BLUELIGHTNIN6
  • 16,542 POSTS
The fuel filter mounts to the top of the fuel tank, pictured below..
fuel filter (1) mounted next to the fuel pump module (2), on top of the fuel tank (3)
https://www.2carpros.com/forum/automotive_pictures/261618_0900c1528003c163_1.jpg
Thanks for using 2CarPros.com!
VHARMS
  • 1993 PLYMOUTH VOYAGER
  • 6 CYL
  • FWD
  • 100,000 MILES
I have a 1993 Plymouth Voyager and need to check the fuel filter. Where is it?
JDL
  • 16,098 POSTS
Hello, look under passenger side, about the middle, mounted in the fuel line
CARADIODOC
  • 33,737 POSTS
What's the symptom? Except for diesel engines, you will never solve a running problem on a Chrysler product by replacing the fuel filter. They pass the largest amount of fuel during coasting. They actually have to pass the lowest volume while accelerating.
Caradiodoc
JBANG
  • 1992 PLYMOUTH VOYAGER
  • 6 CYL
  • AWD
  • 178,000 MILES
I can't find the fuel filter on my 92 plymouth grand voyager. Any suggestions?
JDL
  • 16,098 POSTS
Hi, my info was basic about the location. Under the vehicle, ahead of fuel tank. Sorry, I don't have a picture of location. The filter picture is from napa.
https://www.2carpros.com/forum/automotive_pictures/170934_plymouth_voyager_filter_1.jpg
