2CarPros - Car Questions & Answers
1998 Plymouth Other Repair Question
Topics covered: Radiator, Dealer, Water pump.
Asked on October 4, 2010
1998 Other Plymouth Models Fan motor relay switches
Electrical problem
1998 Other Plymouth Models Automatic
I recently installed a new water pump and my radiator fans quit working. So the dodge dealership said it was probably a bad relay switch. I replaced this but the fans still didn't work. I was told to turn on the ac and see if they came on that way,which they did. So I was told would need to check the connection. How do I do this? Also,the water and antifreeze is leaking out from under the new radiator cap I have,could this be because of a to small cap or because the fans are not working and there is to much pressure on the radiator? Thanks for your help.
Avatar Asked by artistd
No Answer Yet
