1996 Plymouth Other
Engine Mechanical problem
1996 Other Plymouth Models 4 cyl Front Wheel Drive Manual 103289 miles
Hello I recently bought a Neon, I am having problems with it stalling. If you touch the gas when its at idle when you remove your foot it stalls, otherwise it idles fine. Also when driving in town, stop and go, when you pull up to a stop light sometimes it will stall then to. The guy I purchased it from said " Its just cold blooded", but I know something is wrong. I was told that it could be the oxygen sensor, fuel filter, and the mass air flow sensor. Could it be something else? Also is there a way that I can check these things to see if any of them have failed? Any help I can get is greatly appreciated, thank you for your time!
December 22, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
