2CarPros - Car Questions & Answers
1993 Plymouth Other Repair Question
Topics covered: Fuse, Starter, Battery.
Asked on March 28, 2008
1993 Other Plymouth Models Starter is buzzing... and not sta
1993 Plymouth Laser. 1.8L. Manual.
My sister tells the story that the battery mount slipped loose, the battery slid forward and shorted across one of the hood supports. She turned the key off when she saw the smoke, and then tried to start it again. Toasted the battery naturally. But didn't blow any fuses. Her hubby swapped out the starter solenoid (?) and checked the computer (was all good).
Turns out that in his fuse checks he knocked the prong down on one of the fuse boxes and so it wasn't engaging the fuse. Good deal, right?
Still no go. When the key is turned to "start" I get a humming/buzzing/whirring sound from the starter. My first thought is it's just not engaging...
Thoughts?
P.S. Can provide picture/video/audio if that helps.
Avatar Asked by padresmokey
Answer
Replied on March 28, 2008
my first thought is the starter motor got fried too. check wiring at the starter motor. chances are the positive cable is melted, causing your problems. or negative cable
Tiny Answered by mastertechtim
7 questions asked
