Mechanics
TRANSMISSION LEAK
1995 Plymouth Acclaim
Transmission problem
1995 Plymouth Acclaim 6 cyl Front Wheel Drive Automatic 111902 miles
I have a 1995 plymouth acclaim with some minor problems. My passenger side cv-joint is getting ready to break and going to fix that asap. I have a small transmission leak that I dont know where its coming from I was told it's possibly coming from the cv-shaft. Im just wondering if there is another spot. The transmission pan is tight and no leak from there.
Ekim88
August 1, 2009.
If you have a CV joint that is that bad, chances are the leak is coming from the axle seal where the axle enters the transaxle.
AD
