Mechanics
PLEASE HELP ME DIAGNOSES AND FIX MY TRUCK
2008 Dodge Ram • 204 miles
The truck ( 2008 dodge ram 1500 hemi 2wd) will jerk (slam on brakes) when driven between 60-65mph, once you exceed that speed it will stop. As long as you are between those speeds it will jerk (slam on brakes). I have try to replace the speed sensor, remove the abs fuse. I do not know what else to do. Please help, I need an affordable way to fix my truck
Veedjay
June 13, 2013.
First thing I would do is get the computer (OB2) scanned. This will make it easier to help in the diagnosis. Most auto part stores will do this for free. When you get the codes, write them down and let me know what they are. There are many problems that could create this symptom and without speculating for hours let's try this out first and I'll be happy to help you out in finding the problem.
Thanks, look forward to your reply
Sean
Seangrant00
Jun 27, 2013.
AD
