1999 Peugeot 206 Repair Question
Asked on October 13, 2008
Engine reving
Engine Mechanical problem
1999 Peugeot 206 4 cyl Two Wheel Drive Manual 87000 miles
My car keeps reving when i'm in traffic or at the lights (this car sometimes be up to 35000 revs).
When i put my foot on the accelerator the revs go back down to what they should normally be.
my battery has also just run flat but i think this is because of the problems with the engine overusing it.
Answer
Replied on October 22, 2008
With thottle cleaner, clean your throttle bore, and your IAC valve; you may even have to replace you idle control motor.
