What causes my van to overheat?
MOTHEROF2
  • 1997 CHEVROLET VENTURE
  • 217 MILES
It was overheating, so I bought and had replaced a new thermostat, also a new water pump. The motor isn't feeling hot, but yet the meter on the dash is showing it's hot.
Monday, November 28th, 2011 AT 2:03 AM
Is it actually overheating/boiling over or just the gauge is telling you its hot-check and test the coolant temperature sensor. This guide can help us fix it
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Monday, November 28th, 2011 AT 2:26 AM
MOTHEROF2
  • 5 POSTS
No it is not boiling over. It is just the gauge. I've replaced the thermostat, and water pump. What can I do?
Monday, November 28th, 2011 AT 7:10 AM
Test the CTS
Monday, November 28th, 2011 AT 7:16 AM
MOTHEROF2
  • 5 POSTS
How do I do that?
Monday, November 28th, 2011 AT 7:17 AM
Use a digital volt/ohmmeter-Why don't you just bring her in
Monday, November 28th, 2011 AT 3:57 PM
MOTHEROF2
  • 5 POSTS
I don't have the extra cash to spend. I'm a low income ****** of 2, trying to make it. I bought the Coolant/Temperature sensor today to put on it, so maybe this will fix it! :)
Tuesday, November 29th, 2011 AT 6:24 AM
Are the cooling fans coming on?
Tuesday, November 29th, 2011 AT 6:43 AM
MOTHEROF2
  • 5 POSTS
Yes, they are comming on.
Thursday, December 1st, 2011 AT 4:44 AM
Did you replace the CTS -if it continues have it block and pressure tested-Could be the temperature gauge is out of calibration
Thursday, December 1st, 2011 AT 7:19 PM
TRAYE_BONNETT
1997 Chevorlet Venture leaks antifreeze in back of motor and overheats easily.
Friday, August 21st, 2020 AT 11:55 AM (Merged)
JDL
  • 16,098 POSTS
You need to find the leak and fix it, I can't tell where it is without looking?
As far as overheating does it boil-over? Check the thermostat-- radiator fan--coolant flow-- check for combustion gases in the coolant.
HOCKEY24
  • 160,000 MILES
Van over heat then when gauges get to red it goes back down. Checked for leakes but there are none. Oil is fine
  • 52,797 POSTS
Check the thermostat as that may have been the issue but now I would also suspect a head gasket from the overheating. Have a leak down test done to be sure
1CHEVEYMAN
I just bought a chevy venture van 1997 3.4 6 cyl. And when you drive it it dont overheat however if you stop and let it idle for afew minutes it gets hot!
Any one have any idea what the prblem is with it?
TOSHA
  • 5 POSTS
Try changing your thourmoastat pretty cheap fix about 4 too 5 bucks
