2CarPros - Car Questions & Answers
Opel Other Repair Question
Topics covered: Thermostat, Water pump.
Asked on June 26, 2006
Temperature problems
Opel astra model 2000 1.6-16v
i had a problem in hight temperature levels 9it shows oin the board more tahn 100 deg and reaches red levels). i changed thermostat first but problem persist so i cleaned the cooler but no changes. after testing the cooler i found 90deg temperature in its entrance and a 30 deg in its out so i was advised to change the computer of fans i changed it and no changes . then i changed the cooler and the water pump (i kept the new computer) here i had the solution.
i tried my original computer but the indicator on the board lights up noticing a problem so i was told that my original computer is defected i kept the new one.
now after one week the new computer indicates the same light on the board , first the high speed fans are on at low level temperatures and after a while all fans are stopped and never been on again even when i turn on the air conditionner fans never start and the compressor turn off.
n.b: when i changed the computer there was no reset made to it.
can you help me , i will be greatfull
thanks a lot
Avatar Asked by tony_s
Answer
Replied on March 15, 2009
the computer needs to be read for fault codes .. then reset to your vehicles setting's ..and road tested again !!
Tiny Answered by Dave H (expert)
13,682 answers provided
