2CarPros - Car Questions & Answers
1998 Opel Other Repair Question
Topics covered: Mechanic, Coolant, Crankshaft.
Asked on September 7, 2007
Same '98 Corsa: oil from crankcase?
As reported yesterday, my '98 Corsa had a hole in the breather hose, a.k.a. crankshaft (or "crankcase"? heard both versions) ventilation hose. I replaced the hose and the previous problem went away; the engine also became quieter.
But the hole in the hose was obviously made on purpose, by the previous owber's mechanic! (I only own the car for the last 5 months and 5000 miles). The only purpose I can think of is that there is too much oil coming out of the crankcase. And indeed, there is a rather significant layer of oil on the throttle.
On the other hand, that mechanic probably was a strange person - he also put in water instead of coolant...
So my questions are:
- Is it safe to drive the car as it is now, with the repaired hose? What can be the threat if there is indeed too much oil? What should I look out for?
- Can anything be done to hold that oil, apart from diverting it by hole or by redirecting the hose completely? A friend suggested putting a "brush" of metal into the hose (a standard accesory for a Lada Niva, of all things) so the oil would be condensed and then would flow back into the crankcase - would this work?
- Finally, is there a way to check whether excessive oil is coming and to reduce it? Apart from a rebore...
Thanks a lot! For now, you have been the only source of information that actually worked.
Avatar Asked by Michael_Ireland
No Answer Yet
