1989 Opel Calibra no start
DANNYOB
  • 1989 OPEL CALIBRA
  • 4 CYL
  • MANUAL
  • 169,000 MILES
I doing up this calibra it hasnt run for 3 years iv had it running before. I changed timing belt now starts once for a second then dies. There is fuel and spark at plugs ht leads are good and good compression and fuel pump and relay are all ok?
Tuesday, June 8th, 2010 AT 3:38 PM
Check the fuel pressure to rule the filter and fuel pump and also if the injectors are pulsing
Tuesday, June 8th, 2010 AT 4:43 PM
DANNYOB
  • 7 POSTS
Whats best way to check injectors are working?
Wednesday, June 9th, 2010 AT 3:27 PM
Listen to it if its clicking they all should sound the same or check its solenoid resistances
Wednesday, June 9th, 2010 AT 3:35 PM
DANNYOB
  • 7 POSTS
Thanks will check that out
Wednesday, June 9th, 2010 AT 4:36 PM
DANNYOB
  • 7 POSTS
Where is the crankshaft sencor located?
Friday, June 11th, 2010 AT 2:07 PM
I don't have that information in my reference Mit1 or Alldata-sorry
Friday, June 11th, 2010 AT 6:09 PM
DANNYOB
  • 7 POSTS
Sorted was crank sensor. New prob oil pressure
light was on I openend oil sump and petrol came gushing out how could this be?
Monday, June 14th, 2010 AT 2:32 PM
Injectors and fuel pressure regulator are leaking
Monday, June 14th, 2010 AT 3:49 PM
DANNYOB
  • 7 POSTS
Thanks ras. Do I need to replace injectors or just the rubber seals the later I hope?
Monday, June 14th, 2010 AT 3:58 PM
Investigate before you start throwing parts to it that your childrens could use in the future
Monday, June 14th, 2010 AT 4:05 PM
DANNYOB
  • 7 POSTS
Hi my calibra starts for a second then dies getting petrol in sump and oil filter. So I think it starts when all fuel has drained into sump etc then floods and turns over but wont start how is fuel getting in sump and oil filter?
Monday, July 12th, 2010 AT 2:03 PM
