Mechanics
ONE CYL NOT FIRING.
2002 Ford Taurus • 137,000 miles
I replaced coil, plugs, wires, fuel filter, has real low power the # 6 plug is not firing has 6 new injectors in it, have replaced the sencors when it starts it idles fine but when you drive it ther is very little power.
Jay Owens
May 9, 2013.
Compression test, fuel pressure test and cat converter back pressure test. Start there as one of them will define your issue
AD
