The driver side power window on my 2000 Olds Silhouette with 100K miles will not go up. i took apart the door panel and removed the motor. The motor will spin one way (down) when I press the window switch but will not spin up when I press the switch the other way. I replaced the motor because my old motor did the same thing (would only spin one way) and I thought it was broke. The other window works fine.
Nov 10, 2007 at 11:06 AM
