Oldsmobile Other Repair Question
Topics covered: Turn signal switch, Fuse.
Asked on March 12, 2007
Turn signal switch
Where can i find the turn signal switch on a 98 Olds Aurora. right turn signal not working. I checked all the bulbs, they are ok. the flashers work and the fuses are ok. don't know if it is the turn singnal switch or the turn signal flasher, or are they one in the same???
Answer
Replied on March 12, 2007
the turn signal switch is what you pull to turn , the flasher is under the dash
Jim
