1999 Oldsmobile Other
I have a 1999 olds alero with about 158000 miles on it and a couple of weeks ago the instrument panel would go blank while driving and then come back on with no warning. When the i/p would go blank I did not have any driveability problems. Also when the i/p went blank I noticed that the blower moter and electric windows would not work. I scanned a few wiring diagrams for this car and noticed that the only thing these three systems have in common is the body control module (BCM). I replaced the BCM and performed the passkey relearn procedure and the car started fine. However, the i/p and everything else still is not working. Also just recently I noticed that if I turn on the blower while the i/p is working sometimes the i/p and blower will stop working. The problem is becoming more common now and I'm starting to think that there is a relay problem or a grounding problem. I did not see a relay in the wiring diagram though, but that may just be that I have an incomplete wiring diagram. I'm fairly handy with a DVOM if someone can point me in the right direction for more troubleshooting procedures I'd appreciate it.
January 4, 2006.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
