1998 Oldsmobile Other Repair Question
Topics covered: Check engine light, Engine, Gas.
Asked on September 19, 2008
1998 Other Oldsmobile Models Head gaskets
1998 Other Oldsmobile Models 6 cyl Front Wheel Drive Automatic 140000 miles
I have a '98 Oldsmobile intrigue & the temperature gauge shot up to high, the check engine light came on, & started to run rough. I brought it in for an estimate & they said it was the water pump – I replaced it – it started right up, I drove it for a mile or so – got home & white smoke came out the back & started running really rough. I turned it off & now it won’t start, it does turn over & the power is there, just won’t start.
I’m thinking that the upper intake manifold probably has antifreeze in the cylinders, but can’t determine if the head gasket would have gone bad also??? What do you think – drove on the needle on high for about 20 minutes…
