1996 Oldsmobile Other Repair Question
Topics covered: Window, Window switch, Fuse.
Asked on September 30, 2008
1996 Other Oldsmobile Models car dies
Electrical problem
1996 Other Oldsmobile Models 6 cyl Front Wheel Drive Automatic 189000 miles
at first it started by hitting window switch car died would not start again by luck i wiggled switch car fired up hit window switch again trying to get started did not work. when problem happens i have no window motors seat motors or fuel pressure. I do have spark and have replaced the ignition module so far all fuses and breakers check out and have power. except i have found some more fuses and relays behind glove compartment that I have not checked. After replacing ignition module car did not start right away it eventually did and ran for a day or two then all of a sudden without hitting seat or window switches car died again everthing works except for having fuel psi windows and seats
