2001 Oldsmobile Intrigue
Engine Mechanical problem
2001 Oldsmobile Intrigue 6 cyl Front Wheel Drive Automatic 102568 miles
I have a P410 engine code that will not go away. I have replaced the secondary air pump 3 times as the light keeps coming back and the mechanic just said the pump needed replacing.
After the first time there was some water in the system and when the pump was replaced again, there was a drainage kit that was added.
I can also hear the airpump cycle on/off many times while driving - even after the car has warmed up.
What else could be causing this problem? Im thinking it could be one of the valves but I have been to two parts stores and they have no idea what the name/part number for the valves.
Here is a link to the valve I would like to try and replace:
Thanks for your help!
Pilot Mark
June 18, 2010.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
