1998 Oldsmobile Intrigue Repair Question
Topics covered: Gas, Engine, Fuel pressure.
Asked on January 31, 2010
1998 Oldsmobile Intrigue possable ign elect problem or some
Engine Mechanical problem
1998 Oldsmobile Intrigue 6 cyl Two Wheel Drive Automatic 117000 miles
car will start and run fine some time and then it will run like it has loss some cylinder, it does not throw acode but it wont start sometimes and some time when it starts you got to keep messing with the gas peddel to keed it running barely and when you let off the gas it will die, but then it might sarty back up and run fine for a while.l fuel pump is got mass flow senor and can and crank senor is ok
what could this be ???? thanks john
Answer
Replied on April 13, 2010
John:
It sounds like you checked most of the sensors and fuel pressure. Have you checked for vacuum leaks?
