2CarPros - Car Questions & Answers
1995 Oldsmobile Delta 88 Repair Question
Topics covered: Spark, Engine, Smell.
Asked on March 21, 2009
1995 Oldsmobile Delta 88 it just want start
1995 Oldsmobile Delta 88 V8 All Wheel Drive Automatic 116,54 miles
my car drove fine all day and then i went to start it,it started fine but i put it in drive pull of and started putting and i smelled this smell like something burning i turned it off and then it just didn't start back at all the lights and air and all that came on but no car start i need my car really bad please help so i can know what to fix!
Avatar Asked by jessica859
Answer
Replied on March 21, 2009
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Tiny Answered by rasmataz
68 questions asked
