This isn't an actual question - more like an answer for some of you. I had a problem with the car stalling every time I stopped at a turn or light. It ended up stalling and not starting again after awhile. It turned over but wouldn't start. Everyone was baffled. We change the CPS and fuel pump. Anyway, it ended up being the coil pack. We also changed the spark command module at the same time. Picked up these parts at a junk yard for 30 bucks. 2 years the car sat. After the replacements, the car started right up and is doing fine ever since. Hope this helps someone.
Mar 23, 2010 at 11:21 PM
