Mechanics
FUEL PUMP
1994 Oldsmobile Ciera
Engine Mechanical problem
1994 Oldsmobile Ciera 6 cyl Two Wheel Drive Automatic
I got a 1994 olds cutlass ciera and I think the fuel pump is going out. I changed the fuel filter already. It started when my car would get down to 1/4 tank bit would act like it was out and I would pump gas pedal to get somewere safe. I would let car sit for a while and it start so I never let it get under 1/2 tank to fix problem haha. Now its worse when it gets hot outside it would not start at all just turn over. Would start next morning and is now happening all time some one said to turn key on and liten under gas tank to see if I can hear fuel pump. Car wont start now and I dont hear anything under tank so please help ps. Is there a way check fuel pressure
Craigzlc
May 22, 2009.
Check the fuel pump fuse and fuel pump relay-if okay power the fuel pump connector gray wire from the battery did it come on.
Rasmataz
May 22, 2009.
AD
