Mechanics
OLDSMOBILE CIERA FUEL PRESSURE PROBLEM
1993 Oldsmobile Ciera
1993 Oldsmobile Ciera 6 cyl Front Wheel Drive Automatic
my aunt has a 1993 olds cutlass ciera s and the car would cut off driving or idling so I changed the fuel pump and filter but now it does not idle or have any type of power and it still cuts off but you can cut the key off and wait about 30 seconds and start it back up and it run for 5 to 10 minutes till it does it again and I am also wondering how to jump the diagnostic port terminals to get the codes by the blinking lights and the code descriptions thanks
James31983
June 17, 2010.
http://www.2carpros.com/trouble_codes/obd1_trouble_codes/buick_cadillac_chevy_gmc_oldsmobile_pontiac_gm_codes.htm
The above link should give you info for accessing trouble codes. When the problem first started did you use a gage and check fuel pressure?
Internetmechanic
Jun 17, 2010.
AD
