Mechanics
FUEL PUMP OR FILTER
2002 Oldsmobile Bravada
Engine Mechanical problem
2002 Oldsmobile Bravada 6 cyl Two Wheel Drive Automatic 100000 miles
car ran fine one day then wont start no fuel comming to shreader valve on fuel line. Is pump bad or filter bad, or electrical
Christinalo
February 23, 2009.
Can you hear fuel pump buzzing for a couple of seconds when first turning key in ignition? If no, inspect fuel pump relay and/or fuel pump fuse. If fuse/relay is OK, need to test wiring at pump for power. Dirty filter would not normally prevent fuel flow, only restrict it.
Thanks for using 2CarPros. Com!
Bluelightnin6
Feb 24, 2009.
AD
