2CarPros - Car Questions & Answers
2002 Oldsmobile Alero Repair Question
Topics covered: Spark, Engine, Fuel filter.
Asked on July 15, 2010
2002 Oldsmobile Alero starting
Engine Mechanical problem
2002 Oldsmobile Alero 4 cyl Front Wheel Drive Automatic 142xxx miles
i been having troubles starting my car it will crank but just wont start i have recently changed the spark plugs and the fuel filter but nothing has helped
Avatar Asked by stullboy09
Answer
Replied on July 16, 2010
Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Tiny Answered by rasmataz
68 questions asked
