Mechanics
TCC
1998 Oldsmobile Achieva
Transmission problem
1998 Oldsmobile Achieva 6 cyl Front Wheel Drive Automatic 135000 miles
1998 oldsmobile, acheiva seemed to be missing between spends 58-70. Replace the plugs and wires, throttle sensor, after more checking I deciede it was the TCC kicking in and out at these speeds, I checked all connections and tighten them. Only one time did I get a code and it said loose connection. I also changed fluid and filter in transmission. I can put it in drive and runs fine, seems to be only in overdrive when this jerking happens. Do you have any suggestions of what I should check.
Thanks
gfj
AD
Gfj
November 23, 2009.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
