Marker lighting
DWB812
  • 1993 OLDSMOBILE ACHIEVA
  • 4 CYL
  • FWD
  • 207,000 MILES
Is anyone able to provide me a detailed schematic of the Olds Achieva (1993 2.4L) marker lights circuit. I have the rear marker lights out but brake and turn signals work. I have checked bulbs and have no voltage to marker light pins in the 5 pin connector at tail light module. Also, dash lights are out. I suspect the switch (turn signal multi-function) has an open. The front marker lights work tho' and I'm not sure how the circuits are laid out. A schematic would be very helpful as the Chilton's manual I have has really lousy ones.
Thursday, January 20th, 2011 AT 6:34 PM
  • 108,179 POSTS
Here are schematics for lighting. Let me know if they help.
Thursday, January 20th, 2011 AT 7:13 PM
JDL
  • 16,098 POSTS
In the diagram for the side marker lamp, the wire that ties in above the tail lamp in the diagram, is voltage, the other is ground. Bulb and bulb socket wiring all ok?
Thursday, January 20th, 2011 AT 7:26 PM
  • 108,179 POSTS
Thank you JDL. I don't know why my schematics didn't get sent. I sent 3 different ones for all lighting circuits.
Thursday, January 20th, 2011 AT 8:59 PM
JDL
  • 16,098 POSTS
I didn't see you there before I posted, I don't know what happened? Have a good day.
Thursday, January 20th, 2011 AT 9:18 PM
  • 108,179 POSTS
Not a problem. It worked out to benefit all.
Friday, January 21st, 2011 AT 12:50 AM
DWB812
  • 108 POSTS
Thanks guys but the junction at the top of that diagram is where I suspect the problem is. Since I have voltage at the licence plate, brake lights, and turn signals but no running (or marker/park lights if you prefer) I am inclined to thinki there is an open in that area. Does antone know where that junction is located in the car. I would be interested in seeing those other schematics or diagrams if possible also.
Tuesday, January 25th, 2011 AT 11:36 PM
JDL
  • 16,098 POSTS
In the diagram which wire doesn't have voltage?
Wednesday, January 26th, 2011 AT 4:04 PM
DWB812
  • 108 POSTS
It was the brown to the marker lights lke I said. No worries tho. I took the switch apart and cleaned all the contacts and it works now. The dash is a different story. I got the dash lights working but the idiot light for the oil pressure is on all the time. Is sensor failure a common problem on these? Also, any wiring diagrams which include the dashboard warning (idiot) lights would be helpful.
Sunday, January 30th, 2011 AT 5:08 PM
  • 108,179 POSTS
It could be a sensor or a ground issue. The only schematic for the inst cluster I could find is for lighting. If you need it, I have attached it.
Sunday, January 30th, 2011 AT 7:01 PM
DWB812
  • 108 POSTS
Thnx J&N I found the ground issue and all is well.
Wednesday, April 13th, 2011 AT 9:15 PM
  • 108,179 POSTS
Glad you got it fixed.
Thursday, April 14th, 2011 AT 1:04 PM
DWB812
  • 108 POSTS
Thanks. That filthy and corroded light switch was a big tip off as to the rest of the story. Appreciate all the diagrams. Where does a guy get that stuff.A subscription service?
Tuesday, April 19th, 2011 AT 8:55 AM
JDL
  • 16,098 POSTS
Mitchel and alldata have a yearly fee for single vehicles. Maybe 20 bucks for a year, same info we have.
Large libraries have automotive databases. If you live in the area they serve, it's free. One of the databases, you can access on your home computer. Not as good as Mitchel or alldata, but, better than nothing. The one library I suscribe, they are updating their database, supposed to be straight out of the factory manual, some good info.
Tuesday, April 19th, 2011 AT 2:29 PM
DRAGONSILVER
  • 1995 OLDSMOBILE ACHIEVA
  • 6 CYL
  • FWD
  • 225,030 MILES
I have no tail lights or gauge lights, I have checked the fuses and bulbs in the tail lights and all are fine. They both went out at the same time
Wednesday, January 3rd, 2018 AT 5:49 PM (Merged)
TOMMYFUBU85
I know you asked this question like 3 months ago. But maybe you are still having this problem? I had this same problem in my achieva, and it was the main switch.(Headlights and turn signal switch.)
DWB812
  • 108 POSTS
Yep, same thing happened to a friend of mine's. Cleaned the headlight switch and everything works fine.
GENOCUSHEN
  • 1997 OLDSMOBILE ACHIEVA
  • 4 CYL
  • FWD
  • 15,700 MILES
Electrical problem
1997 Oldsmobile Achieva 4 cyl Front Wheel Drive Automatic 157, 00 miles
my running lights have stopped working during the day and the brights indicator flashes the while the car is on, but once night comes the running lights are on and the bright indicator is not. How do I get them working in the day time again?
  • 108,179 POSTS
Have the high beam multi switch checked.
