1990 Oldsmobile 98 no start
1990 OLDSMOBILE 98
WESTER CAT
Electrical problem
1990 Oldsmobile 98 6 cyl Front Wheel Drive Automatic
when I turn the ignition on the dash warning lights come on but it will not start. The engine does not turn over. There is ignition power and start signal coming from the ignition switch. There is no power at the starter solenoid from the key switch. I checked the transaxle position switch and it is fine. There is no start signal going to the transaxle position switch. I hope you guys can help. Thank you.
May 13, 2009 at 4:06 PM
