oil pump
2002 FORD F-150
2,782,530 MILES • 4.6L • V8 • 2WD • AUTOMATIC
JOHN LARIVE
running good no issues-changed oil-filter-refill with 5 Qt.recommended motor craft 5-20 and motor craft filter. started engine for a sec. shut it off to give oil a chance to start circulate and started avian run a few minutes oil pressure was good on gauge. check oil and showed very low on dip stick not even to the low level mark?
Aug 10, 2019 at 11:52 AM
