Location of oil sensor please!
CLYDEDAVIS
  • 2010 CHEVROLET IMPALA
  • FWD
Location of oil sending unit/do starter need to be removed to replace it? Please help I love this site.
Wednesday, June 10th, 2015 AT 4:51 PM
HMAC300
  • 48,601 POSTS
Hello
The starter does not need to be removed. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Cheers
Thursday, June 11th, 2015 AT 5:59 AM
022750EW
  • 2005 CHEVROLET IMPALA
  • 6 CYL
Where is the oil pressure switch located on a 2005 chevy impala 3.4?
Saturday, October 27th, 2018 AT 7:46 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
The oil pressure sensor is on the lower left side engine. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
MRHAGBERG
  • 2007 CHEVROLET IMPALA
  • 6 CYL
  • 150,752 MILES
Where is the oil sensor located on a 2007 chevy impala ltz 3.9?
Engine Oil Pressure (EOP) Sensor (3.5L, 3.9L) Right of starter.
MRHAGBERG
Thank you for the information. I have 3.9 liter motor in the picture shows the 3.5 liter. On my motor there is a heat shield where it would appear that the oil filter would be in the illustration. Do I have to remove the heat shield to get at the oil sensor? Is there anything beyond that I need to beware of?
Thank you get your help
CASSIE88
  • V8
  • FWD
  • 60,000 MILES
Where is the oil pressure sensor in a 07 chevy impala ss?
Engine Oil Pressure Sensor and/or Switch Replacement
Tools Required
J 41712 Oil Pressure Sensor Socket
Removal Procedure
If necessary, remove the engine sight shield. Refer to Upper Intake Manifold Sight Shield Replacement.
Disconnect the oil pressure sensor electrical connector (4).
Using J 41712, remove the oil pressure sensor (706) and washer (707).
2CP-ARCHIVES
  • 4,542 POSTS
  • 2006 CHEVROLET IMPALA
  • 165,000 MILES
What is the location of the Oil Pressure sending unit
  • 52,797 POSTS
Just above the oil filter.
It is a general answer since you provided no engine size
MAXANDMICKEY
  • 3.5L
  • 6 CYL
  • FWD
Could you please tell me the location of the oil pressure sensor on a 2007 impala 6cyl flex fuel 3.5 thank you
HMAC300
  • 48,601 POSTS
See pic its by oil filter
TWIN87
  • 2002 CHEVROLET IMPALA
  • V8
  • FWD
  • 157,812 MILES
Where is the oil sending unit located on a chevy impala
JDL
  • 16,098 POSTS
Hello, it appears to be located above the starter.
TPENN12
  • 101,000 MILES
Can you email me an accurate diagram of the oil pressure sensor location on a 2007 chevrolet impala with the 3.9L engine or, at least provide some direction on how to locate? Some illustrations show it on the right side of the top manifold other info I've gotten says it could be located at the bottom of the engine near the oil filter.
CJ MEDEVAC
  • 11,004 POSTS
. DIS WHAT YOU NEED?
THE MEDIC
LAURALEEWALKER
  • V8
Where is oil pressure sending unit located on 2006 impala
Engine Oil Pressure (EOP) Sensor (5.3L) Below throttle body.
RSASH23
  • 2008 CHEVROLET IMPALA
  • 130,000 MILES
I can't locate the oil pressure switch on my 3.5L V6
  • 52,797 POSTS
Right above the oil filter
