Mechanics
OIL LEAKING FROM THE PETROL PUMP AND WHITE SMOKE
1995 Toyota Corolla • 1.3L 4 cylinder 2WD Manual • 238,579 miles
Good day, I own a 1995 Toyota corolla 1300 2E my problem with my car its leaking a lot of oil via the petrol pum I've steam cleaned the engine to find out where the leak was and it was coming from the petrol pump its also smoking a lot the smoke is a white color but the exauhst pipe is full of. Black stuff ( burnt oil ) the car doesn't really have pull away power and seems to be getting worse by the day Can You tell me what I can do or what is wrong with my baby
95bubbles
November 24, 2013.
The fuel pump is leaking from the breather hole, it will have to be replaced and get the engine tested for a blown head gasket, are you having to add extra coolant?
Mhpautos
Nov 24, 2013.
