Mechanics
NO SPARK OR FUEL AFTER ENGINE HOT
1990 Honda Accord • 160 miles
This is the 4cyl injected engine. Helping my neighbors friend whose car stalled out front. He tells me that this has been going on for quite a while. Also that the car usually starts fine once its cooled off. I checked the honda boards and it seems others had had main relays issues.
The main relay was my first thought as well. I havent mapped out the electrical yet to the coil or the pump, looking for a wiring guide. Also looking for a wiring guide for the main relay as well.
Diceberg
September 14, 2013.
The main relay would not result in loss of sparks. If sparks is missing, I would suggest checking the ignition switch.
Ensure you have battery voltage at the ignition coil while cranking.
AD
KHLow2008
Sep 14, 2013.
It is pretty unusual to have a no spark and no fuel condition at the same time. Is your coil internal or external of the distributor? You can pull out the main relay and check for cracking solder joints inside to see if that might be your no fuel problem.
Hondatech1983
Nov 21, 2013.
AD
