It looks like the hazard flasher relay is located behind the drivers side kick panel, the flasher is on a bracket behind the fuse block. See the attached picture for the location and wiring diagram. I have also attached a guide for testing wiring should the issue go deeper
Thanks for using 2CarPros.com.
Follow the guide and diagrams below, let us know what you find.
Images (Click to make bigger)
SPONSORED LINKS
Tuesday, July 19th, 2011 AT 12:29 AM
