Idle adjust screw is stripped
APENA
  • 1992 NISSAN TRUCK
Recently, my truck was idling bad and idle was fluctuating from 1600 to ~ 1800 RPM. SPECs state that it should be 750 +- 50 RPM. When I went to adjust the idle during a tune-up, according to the service manual, I could not since the idle screw seemed to be "stuck" and somewhat "stripped".
This was probably done during the last tune-up more than a year ago and that mechanic shop is no longer in business.
Can I "drill" the screw out with a screw extractor? Or--is this screw set so that it will NOT screw out? I hope I can fix this since a new throttle body is quite expensive.
http://www.2carpros.com/forum/automotive_pictures/115045_IdleSpeedAdjust_01_1.jpg
Thursday, November 8th, 2007 AT 2:17 PM
Here is a video of how you can remove a stripped screw to fix the problems.
https://youtu.be/YDt5OUIZTs0
If this doesn't work you will need to replace the throttle body here is a guide.
https://www.2carpros.com/articles/how-a-throttle-body-works
Saturday, November 10th, 2007 AT 9:56 AM
ALLCEAYT
  • 1989 NISSAN TRUCK
Engine Mechanical problem
1989 Nissan Truck 4 cyl Two Wheel Drive Manual
I need to lower my idle on my truck and cannot do in on the carb.
Monday, January 21st, 2019 AT 8:05 PM (Merged)
Try adjusting the fast idle cam and choke opening using the repair manual and then adjust the curb idle speed.
