1987 Nissan Truck Repair Question
Topics covered: Engine, Four wheel drive, Harmonic balancer.
Asked on May 13, 2010
1987 Nissan Truck Engine swap from v-6 3.0 to l-4 2.4 liter
Engine Mechanical problem
1987 Nissan Truck 6 cyl Four Wheel Drive Manual
I have a 1987 4x4 manual trans pickup with the 3.0 v6 in it which I took to a local repair shop and they messed up the crank by putting to small of key for the timing sprocket and harmonic balancer susquently causing the key slot to elongate and grossly put the engine out of time causing major valve clatter and oil usage. I want to know by replacing the v6 with a 1992 2.4L 4cyl manual trans will my wiring harness in the 87 work? I believe I need to change out the computer under the seat and reroute ac lines but what other suprises should I expect? Please advise, Greg
