1990 Nissan Stanza
Engine Mechanical problem
1990 Nissan Stanza 4 cyl Front Wheel Drive Automatic 315048 miles
i took my car to a shop because it keeped stalling out on me. i could let it sit for a bit and then itwould fire back in like 2-60mins.. it will run for a while and then the motor would just stall out agine and would not fire back i replaced my spark plugs. wires, coil, because i was not getting any spark.. so i take my car to a shop tells me it was my distributor and that it need to be replaced so i said ok fine let get it fixed.he used a used distributor to see if that was the problem thenhe justleft the uesd distributor in my car ..after i got my car back it has not been running the same as what it was befor . it has high rev's when taking off from a start.. when it shift gears it revs out to like 3-5 depending how heavy foot is feeling :) and when i got to pass another car in overdrive the revs speed up but the car is not speeding up it seem like it dosent shift gears right any more .. what
could i do to fix my car trouble.. i
February 23, 2009.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
