Mechanics
OVERHEATING
2003 Nissan Sentra
Engine Cooling problem
2003 Nissan Sentra 4 cyl Two Wheel Drive Automatic 105000 miles
My car has started to overheat.I am losing coolant through the resevoir overflow. I have replaced the radiator cap and the thermostant. I have checked the oil and it looks fine, no milky residue. The heater works for the first couple of minutes then blows cold air.
Smchairez
October 1, 2008.
Have it chemical tested for a blown head gasket. If the head gasket is bad, it can displace the coolant with air from the combustion chamber and do as you describe, it doesnt have to have milky oil to be bad
Jack42
Oct 1, 2008.
