Removal of starter
ALLENHOBDY
  • 1998 NISSAN SENTRA
  • 4 CYL
  • 107,000 MILES
How do I remove the starter
Saturday, November 28th, 2009 AT 6:43 PM
BLUELIGHTNIN6
  • 16,542 POSTS
REMOVAL
1. Remove battery negative cable from battery.
2. Remove intake air duct.
3. Remove starter motor mounting bolts.
4. Remove battery cable from starter motor.
5. Disconnect harness connector from starter motor harness.
6. Remove starter motor:
- from transaxle side [GA engine (M/T)].
- from engine side [GA engine (A/T)].
INSTALLATION
Installation procedure is basically the reverse order of removal.
Torque: 31 - 42 N-m (3.3 - 4.3 kg-m, 23 - 31ft-lb)
Read this guide on replacing a starter, its not vehicle specific, but it will give you a good idea of whats involved with this project
Saturday, December 5th, 2009 AT 9:55 PM
JONZUEHLKE
  • 1999 NISSAN SENTRA
  • 2.0L
  • 4 CYL
  • 230,000 MILES
Not -remove battery connection, locate starter, remove wires, remove mounting bolts, reverse order.
Bolt on driver's side on top- I removed the battery and moved the air intake and can reach it with an extension.
Everything on the opposite side is surrounded by exhaust manifold on top, engine block in front, transmission below, and an angled metal shield (upside-down V) behind. Even if I can remove the bolt and wire nuts a path out and back in does not exist (especially through the bottom as recommended).
Any ideas?
Thanks,
Jon Zuehlke
Tuesday, January 1st, 2019 AT 5:57 PM (Merged)
HMAC300
  • 48,601 POSTS
I thas to come out of bottom of car not top. If a shield is in the way remove that
MACMC
  • 1997 NISSAN SENTRA
Help! Trying to replace the starter on a 1997 Nissan Sentra. Have removed both bolts and the starter will not budge. I have hit it, cursed at it, prayed to it and cried like a little baby and the starter will not budge.
Any suggestions.
1997 Nissan Sentra
1.6
automatic
Lol You forgot to spit at it, apply the elbow grease and hook on the skyhooks and yank the heck out of it-but 1st try to turn the crankshaft over by hand. If all else fails put the C4 on it move out real quickly like what am doing on the top left corner.
Continue to be stubborn get in between the starter housing and engine use chisel and make a big bang.
TOMAC BLACK
  • 1993 NISSAN SENTRA
  • 4 CYL
  • 130,000 MILES
1993 Nissan Sentra starter removal, I can get to one of the mounting bolts on the starter, but the one between the starter motor and engine block
seems impossible to reach. Any suggestions?
SATURNTECH9
  • 30,870 POSTS
Extension with a wobble socket or wobble adapter with a magnetic socket to hold the bolt in place.
The easy way is to remove the airflow meter go thru there instead from the bottom been there with that other bolt-
MRSVC2U
  • 4 CYL
  • FWD
  • 103,000 MILES
Where is it located and what are the symptoms of a bad starter?
BMRFIXIT
  • 19,053 POSTS
Under the intake manifold
some of the symptoms: no start ---clicking ... Wining
