Wiper motor fuse and/or relay
JTGUNTER-N-OK
  • 1997 NISSAN SENTRA
  • 1.6L
  • 4 CYL
  • 250,000 MILES
The windshield wiper motor went out on this car a week ago. It made an awful noise and the wipers moved very unevenly across the windshield. It quit all together the second time I went to check it - likely blown fuse or something. I tried to gentle work the wipers but they would not move at all. I pull the motor and checked the linkage. Linkage was fine. I replaced the motor, but I do not know where the fuse is for the wipers, or it their is a relay that could impact the wipers. Nissan is very bad about making information available to fix this stuff. I can figure it out, but if I knew which fuses and relays controlled the thing, it would make life easier. Can you identify fuses and relays that control power to the wiper motor? It has no power right now.
Sunday, April 12th, 2015 AT 11:58 AM
JDL
  • 16,098 POSTS
Is fuse #19 in the fuse panel here is guide to help you test the fuse and the fuse location as well in the diagrams below.
Sunday, April 12th, 2015 AT 12:20 PM
AESCUTIE
  • 4 CYL
  • FWD
  • MANUAL
  • 192,000 MILES
Thanks for your help everyone. I just had my windshield replaced. Shortly thereafter, I changed my windshield wiper blades. The right one comes on and wipes, but the driver's side wiper comes half way up, stops and doesn't work anymore. The wipers were both working properly before changing the blades. I honestly do not believe it had anything to do with the windshield repair either. When I look at the driver's side wiper, it looks to be bent a little though. How can I fix this myself?
Tuesday, October 2nd, 2018 AT 12:32 PM (Merged)
LEGITIMATE007
  • 5,121 POSTS
They could've bent the arm during repair. Try to bend it gently back into place(the arm)
CURT
  • 4 CYL
  • 60,000 MILES
Sentra wipers do not work but motor still works. What do I need to repair, and location of repair.
  • 31,938 POSTS
If the wiper motor is working the regulator that connects the motor to the wiper arms will be faulty, normally a broken pivot drop out the wiper motor to check the pivot.
Mark (mhpautos)
DEEDEE08
  • 1996 NISSAN SENTRA
Automatic 141,000 miles
I just had a new alternator put in because I was told that was the problem, but my locks are locking on there own and my windshield wipers stopped working as well as my horn/ what is the problem?
KHLOW2008
  • 41,815 POSTS
Hi deedee08,
Check the fuses for the wiper and horn.
For the door locking by themselves, check the door lock actuators and linkages.
Should be nothing to do with the alternator.
ICEMANAP928
  • 4 CYL
  • FWD
  • MANUAL
  • 150,000 MILES
The wipers will sometimes work on the low speed but most of the time they don't, also, when wipers are switched off they will stop right where they are instead of returning to the down position and thus obstructing my view. If I try too I can time it just right and catch them in the down position but then im not paying full attention to the road. Any Suggestions/Advise
ZACKMAN
  • 4,202 POSTS
You have to replace the wiper motor.
CEMENTRUCK
  • 4 CYL
  • FWD
  • 130,000 MILES
I turned on my wipers and then I heard a snap. The motor itself I can still hear running but the wipers dont move. I looked under the hood but I cant tell if a belt snapped
  • 31,938 POSTS
Hi there,
the windscreen wiper regulator has failed, this is a rather tricky thing to replace, your mechanic will be the best person for the job.
Mark (mhpautos)
B ALDIRDGE
  • 4 CYL
  • 120,000 MILES
When I turn on the wipers I can here the motor running and something moving but the wiper don't
BMRFIXIT
  • 19,053 POSTS
You need the wiper motor tranny links
dealer sales them they are about $20 or so each
MISSYKERSEY
  • 1995 NISSAN SENTRA
  • 4 CYL
  • FWD
  • 13,900 MILES
The motor for the wipers still work, but they won't move. How do I fix it?
SERVICE WRITER
  • 9,123 POSTS
You need to get to the wiper transmision and see what came apart. Call the dealer with your vin to see if the wiper linkages are available separatley or as a unit (transmission)
DAN MORGAN
  • 6 POSTS
  • 1993 NISSAN SENTRA
Electrical problem
1993 Nissan Sentra 4 cyl Front Wheel Drive Automatic
My vehicle is equiped with the standard off/low/high wiper switch. I would like to convert it to a switch that has a delay option. I think I need to change a relay and buy an alternate wiper switch but I am not sure if this can be done. I am requesting help to identify which relay I would have to replace (as well as what to replace it with) and if there is a delayed wiper switch for my year vehicle. I cant seem to find one online at the autostores. If there is not, can I use an aftermarket switch, and do you have any recommendations.
Thanks for taking your time to help.
Dan
ZACKMAN
  • 4,202 POSTS
It can be done, but it is a long and timely process. You will need to start with a multi function switch out of another Sentra with delay option. You will also need the wiper amplifier (high power relay). I am not sure where the location for B13, but for B14, it is located in the passenger side kick panel. Your vehicle should have the wiring harness for it, except no relay.
BILBO1947
  • 1.6L
  • 4 CYL
  • FWD
  • 180,000 MILES
While working on my son's car I grounded the positive side of battery to something in the car. Now the windshield wipers will not shut off and there is a short somewhere. Is it possible I shorted off the relay and if so is it located next to fuses in car on drivers side? There was something down there that got pretty hot. Could that be problem and if so how to get to it. I can see it but not see how to get out. Thank you.
HMAC300
  • 48,601 POSTS
Doing what you did happens a lot if you ever want to disconnect battery always do the negative side first. You could have burnt anything up. There is a fuse for this but no relay so best to check this it may be a switch or amplifier in switch. See pictures check grounds in pictures as well. The switch grounds the motor to work.
POWAP12
  • 4 CYL
  • 140,000 MILES
It rained hard last week and my driver side windshield wiper stopped working. The other windshield wiper is fine and works well. I can't imagine the motor is bad. Let me know what you think.
