Mechanics
PASSENGER SIDE WINDOW NOT WINDING
1993 Nissan Patrol/Safari
Electrical problem
1993 Nissan Patrol/Safari 6 cyl Four Wheel Drive Manual 240k miles
G'day,
I have swapped electric motor and operational swich[up/down] with the good one. Removed the 12volts connector which is going to window motor and checked +12v DC and -12v DC while holding UP and DOWN switch. But I found 11.33v DC, when the motor is connected, while holding the switch for window DOWN[and motor is running] and.32v dc while holding the switch for window UP and motor doesn't run for winding window UP. NOte: All I have checcked this when the motor is not connected to the Regulator assembly[Scissors type]. Window going UP operation cannot be done even from Driver side controls either. I found Switch, motor, OK.
can you pls. Help me with an answer.
thanx,
Kittoo
Kittoo
February 25, 2009.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
