2CarPros - Car Questions & Answers
1990 Nissan Pathfinder Repair Question
Topics covered: Transmission, Gem, Mechanic.
Asked on November 7, 2006
Transmission 1990 nissan pathfinder
I have a 1990 nissan pathfinder, while driving I had a transmission fluid leak and immediatly pulled over and had my vehicle towed (lost about 2 litres of fluid) the mechanic serviced it replaced the oil pump seal. He took it for a test drive. All was going fine untill he heard a pop and then no gear engagement at all.
He pressure tested ports all were at about 0-6 lbs except the reverse port which was at 60 lbs indicating to me that the pump has not failed Is it possible that there is a solenoid or valve that is stuck and can this be checked without dropping the transmission again?
Thanks
Avatar Asked by skinnypuppy40
No Answer Yet
