2000 Nissan Pathfinder
Ok I have a 2000 Nissan Pathfinder with 110, 00 miles. The antifreeze hadn't been changed for about 3 years when I noticed that the engine was running very hot (guage all the way into the red). After determining that the thermostat was opening, I added some antifreeze, because it appeared to be a little low. While driving later that day, the temperature seemed to drop, and then rise. It continued like this the whole time.
The next day I took it to a shop to have the cooling system flushed hoping to remedy the problem. The mechanics however told me I had 3 leaks:
1) at the waterpump
2) upper water outlet
3) throttle body thermo-element seal
^^this one I've found the others I haven't been able to see.
They gave me an estimate of $600 labor + parts for the 3 leaks, the timing belt, and coolant flush.
Now is this a good price, should I shop around a bit, or are some of these fairly easy to fix by yourself?
Thanks so much!
August 18, 2007.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
