1989 Nissan Maxima Repair Question
Topics covered: Water pump, Engine, Fuse.
Asked on April 9, 2006
HELP!!!!! NEED FAST!!!! 1989 NISSAN MAXIMA
I have a leak under my car.....drip.drip.drip.drip.
It leaks when the car is off...could this be my water pump or maybe just the gasket.
Need help fast...... :cry: [/b]
Answer
Replied on April 10, 2006
Before you get too excited, which may already be too late, where is the suspected leak at? Meaning front passenger side, back of engine bay, front of block, drivers side..........etc? I'm assuming that you are aware that after running the car with the A/C you will have condensation from the compressor dripping which is often confused as a leak by those who don't know any better. If ti si your water pump, you would most likely be experienceing an overheating issue as well.
