2CarPros - Car Questions & Answers
2009 Nissan Frontier Repair Question
Topics covered: Sensor, Spark, Abs.
Asked on July 16, 2010
2009 Nissan Frontier loose power and hesitation
Engine Performance problem
2009 Nissan Frontier 6 cyl Four Wheel Drive Automatic 15000 miles
After trany lock up in or out of o/d there is a bad lose of power. During slow acceleration @ 40 mph on a slight up hill grades, keep depressing gas w/ no response the truck starts to skip or lurch then it will down shift. I have started feeling that lurching at higher speeds now but is only present when accelerating up hill grades or when the truck is more taxed. The dealership is trying to say it's normal tork lock up " normal operation".
Avatar Asked by Richard Stryker
Answer
Replied on July 16, 2010
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below:
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Tiny Answered by rasmataz
68 questions asked
