2CarPros - Car Questions & Answers
Nissan Altima Repair Question
Topics covered: Frame, Tire, Corrosion.
Asked on April 29, 2007
Alignment
2003 Nissan Altima
I had the subframe replaced under rear end for the corrosion recall and after the replacement it seems to pull to the right. I had it lined up and it still pulls. The mechanic said it was lined up but I have proof it isn't. This all happened about two months ago but now you can see excessive wear on the front pass tire on the the outside. If the rearend isn't correct will it cause the front to wear tires? I was just wondering if the rear subframe replacement could be causing this?
Avatar Asked by bwilliams
No Answer Yet
