Mechanics
NO DASH LIGHTS OR POWER ANTENNA.
1995 Nissan Altima
I was putting in a new cd player and when I got done the dash lights and the power antenna did not work. I checked all of the wires and fuses and found no problems. All of the wires are right and the fuses are not blown. What are the other possabilities that could be causing this problem?
Videogfiend
January 21, 2006.
Thee antennae needs the trigger off your old head unit, sometimes its a blue wire. If you used Scotch-loks to install the you might have broken the wire in the jacket
Jack42
Feb 8, 2006.
AD
